RS2 headlight part number
  • rotoryboy
    • May 2004
    • 3281
    Will the HID kit fit in the standard headlamps?
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
    • Sidspud
      • 1223
      • Home: Scotland Current: United Nations
      Yes - I have it fitted to my '93 ABY. You'll need to cut a bit off the caps that fit on the back of the lamps, but other than that they fit no problem.
      ex '93 Avant owner
      • Skull
        • 3506
        • Country: Slovenia
        Here is the pic. Can anyone figure something out of it?!?
        Are ths headlights really bad? Sorry i don`t know much about this topic...
        Audi Quattro WR
        • porkkis
          • 1994
          Note that LHD and RHD cars have different part numbers. Of course!
          In my opinion the early type h4+h1 lights are just good. I have them and direct relay connection from the alternator. Especially the mains are waaay better than in ellipsoid unit. My friend has them so comparsion is easy. We both have fairly new headlights, say bought in the last 4 years.
          Car in the image has the newer style ellipsoids but is LHD, I'd ignore the part numbers these Brits give you
          Btw seems that that car would need a bit more than headlight glasses
          • porkkis
            • 1994
            And no! The electric adjustment is not a standard fitment! I don't have them! Maybe on RHD cars..
            And the lights themselves are the same regardless of height adjustment equimpment. The electric motor replaces a manual adjustment screw.
            And AFAIK the needed wires are in the vehicle main harness
            • Skull
              • 3506
              • Country: Slovenia
              #21
              Porkkis: so you are telling me that the headlights al good, and I will be able to mount the eletric motor for the adjustment?!? That would be great! Tnx!!
              Audi Quattro WR
              • porkkis
                • 1994
                Yes. They're all the same. New lights do not include the electric motor.
                • Doug_RS2
                  • 3847
                  #23
                  I don't have motors on my lights.
                  • audiman
                    • 4827
                    Loser! I do. I just cant use them at the moment
                    Tom C - www.rcmr.co.uk
                    Audi UR Quattro
                    Audi 100 C3 2.0 5 cyl 115ps
                    Audi B5 RS4 645ps 911nm
                    • irvind
                      • Oct 2003
                      • 316
                      No motors here either, 93ABY
                      Irvin
                      '08-'0?:
                      '97 Coupe, Kingfisher Blue
                      '01-'08:
                      '93 ABY Coupe, Milltek cat-back, Alpine dvd Sat-Nav/Changer
                      www.irvinduguid.com
                      • Doug_RS2
                        • 3847
                        #26
                        Originally posted by audiman
                        Loser! I do.
                        It improves the handling if you remove them - less weight in the front
                        • Mikes2
                          • 1704
                          having owned S2s with both varieties, the H4 lamps are much better on dipped beam than the ellipsoids. On main beam the ellipsoids are improved but that's probably due to the change in switching.
                          If you require H4 lenses, the Audi part numbers are as follows:
                          894 941 115 B left for right hand traffic
                          895 941 115 C left for left hand traffic
                          895 941 116 B right for right hand traffic
                          895 941 116 C right for left hand traffic
                          Mike
                          http://www.s2-audi.co.uk
                          • sal_s2
                            • 1288
                            • Skull
                              • 3506
                              • Country: Slovenia
                              #29
                              I need the glass for the headlights on the pic above, cuz i`m gonna buy them tomorrow!
                              They sould be a direct fit on a non S2 B4 right?
                              Audi Quattro WR
                              • Graham
                                • 1622
                                #30
                                I have motors in my94 S2 coupe, i thought the episoids are dual handed as i thought there is a lever inside the light which allows you to switch it from left hand driving to right hand driving? So if that is the case it doesnt matter what lights you get as long as you swap the lever to the roads your driving on.
                                Graham
