I've searched a load of other forums as well as this one for clues but need help again.
I'm fairly clued up but I'm not gonna bust this just because I'm in a rush.
I've got a leak into the boot (open it right up and water drains out of it into the wheelwell), bought some buyl sealing bead and am going to re-seal each light on the back one after the other.
Starting with the centre light panel..........................or so I thought
How the funk does this come off? I've removed 3 nuts from the l/h/s side and 5 or so from the r/h/s including the two around the lock assy.
I've taken the number plate and it's surround off also.
But it have no give what so ever. One of the lock assy bolts seems to be holding tight in it's hole but I would expect that even with this I could get a bit of "flex/lift" at the other end.
Is that all there is to it? Is it holding on the bolt? Or is there some sealing tape holding it tight? Do I just need to pull harder?
Looking along the top of the panel and the underside of the boot overhang from the end I can see there is no seal there, Is that normal? It seems to me that any water can run off the back edge of the boot and get in the gap there and therefore into the boot?
