I have water coming down the inside of both the internal A pillar trims, down the back of the dash by the door hinges and pooling in the footwell on both sides. Started over the winter in the heavy frosts and lying snow. Guessing the frost has damaged some seals but can't see what. Had been dry for a couple of weeks but today after being parked facing north for 4 days with the northerly wind, lying snow & rain I had water in the footwells again. Beginning to think there is a leak round the top of the windscreen.
The rubber windscreen surround isn't very firm at the top of the screen so I'm thinking it might be being driven in their when the wind and rain are coming from a particular direction.
Question is, would you expect the windscreen trim to be tight to the bodywork?
I have checked the sunroof drains and they are fine.
Thoughts?
Thoughts?
