Aero Wiper kits - Coupe / Avant - any interest?
  • Rusty
    • 18953
    Just got some aero wipers on the alpinweiss and didn't know if anyone was after a bolt-on kit? Prices are somewhat higher than they once were and discounts/margins are minimal... looking at
    Front kit (Coupe / Avant)
    • 2 arms
    • 2 wipers
    • 2 caps
    • 2 nuts
    • 2 washers
    £125 delivered
    Coupe rear kit
    • 1 arm
    • 1 wiper
    • 1 cap
    • 1 nut
    • 1 washer
    £65 delivered
    Avant rear kit
    • (parts as coupe)
    £30 delivered
    £10 discount when front and rear are purchased together
  • Rusty
    • 18953
    Here's a picture of the end result:-
    • Smiley
      • Jun 2005
      • 329
      The price is a bit high - maybe I would try these aeros for standard arms first..
      But before that i have to check the rear wiper which is not running at all
      '93 Audi S2 Avant panthero black, 412.000km
      '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
      '93 Audi S4 C4 Avant, 260Tkm
      '88 Audi 100 Avant turbo 44Q
      '84 Audi 80 quattro tornado red
      • Rusty
        • 18953
        Yeah, VAG's prices have gone a bit snooker loopy
        • dest
          • 4287
          With a few mods they should look like this:
          Also, you can pick up the Avant rear aero wiper and blade off ebay for £25 delivered.
          • als2
            • Jul 2009
            • 809
            Those different parts then dest? or just set up different??
            AL
            • dest
              • 4287
              Pic was taken from this thread
              This is the old VAG Parts kit, Doug has bent the arm a little to get it to line up.
              But Paul N also made this comment:
              The long (UK) passenger side blade is pants in my opinion - you have to run the blade much higher than driver side and becomes much less visible. I run with two front wipers the same size... then I can keep much lower profile. I have no clearance issues.
              Sure I had to bend the drivers side just a little before fitting but thats all. Wiped area with the shorter passenger blade is obviously a bit shorter than stock but its not in important areas of the screen.
              • irishs2
                • Apr 2009
                • 2455
                Just an honest inquiry, How is this different than the U clip aero blades?
                Eric
                95 S2 Avant under rebuild.
                • Rusty
                  • 18953
                  Uses the aero wiper arms as well as the blades (they attach completely differently to the U clip blades). The arms are most of the cost Am looking for an alternative but VAG aren't stupid, a lot of conversions use Lupo parts so the price goes up. D'Oh.
                  • Rusty
                    • 18953
                    AL
                    Mine need a little tweaking when I get the time. The parts quoted are different. They need a bit of work to fit them, originally look like this when Martyn did the first kit:-
                    • epic
                      • 1317
                      I bought the right hand drive Avant Aero kit from VAG Parts the week before they stopped trading
                      6X2 955 409 C front arm
                      6Q6 955 707 C rear arm
                      6Q6 955 425 A rear wiper blade
                      1J2 955 425 B front wiper blade
                      They're all from VW GOLF acording to Martin an VAG Parts
                      Also the divers arm needs to be bent to stop it touching the windscreen trim
                      • Rusty
                        • 18953
                        As for replicating the VAG Parts kit, the latest parts they used were the lupo items, as per epic's post.
                        Here's the Lupo part numbers I've fitted.
                        • 6X2 955 409C
                        • 6X2 955 410C
                        • 1J2 955 426B
                        • 3B2 955 425E
                        On the coupe the longer passenger side arm is required to prevent the blades from interacting, not sure if this is the case on the Avant. A driver's side arm could be used with a shorter blade, I'll look into this.
                        • s2avant
                          • 2426
                          OE Golf parts used by VAG Parts are NLA and have been for some time.
                          • Rusty
                            • 18953
                            I'll have a look at the 2 driver's side arm option with a shorter blade, should be able to use the passenger side item I have on the rear.
                            • Acidburn
                              • 13459
                              There is some old threads on here about using a merc rear aero blade arm on a coupe - works out around £22 quid for one, stiglet has one on his and I think wolfgang was the other.
