LOL! sunroof is stuck open on tilt! Is there any manual override?
sunroof stuck!
Be really careful pulling that panel down, its really easy to break the tabs off the side facing you.
Originally posted by newshBe really careful pulling that panel down, its really easy to break the tabs off the side facing you.
Apparently there's a cable that runs all the way round the sunroof, could it be that?Irvin
'08-'0?:
'97 Coupe, Kingfisher Blue
'01-'08:
'93 ABY Coupe, Milltek cat-back, Alpine dvd Sat-Nav/Changer
www.irvinduguid.com
Once you have removed that cover, you will see the motor and the drive gear. In the cover you pulled down you should find a S shaped hex key. This should fit into a hex shaped recess in the centre of the drive gear. You should then be able to manually close the sunroof by rotating this S shaped hex key.
If the fault is electrical, it should be relatively simple to fix, if not cheap.
However, the sunroof is driven by a syncromesh gear, fitting into two cables that are located in the sunroof cartridge. These work like a rack and pinion. The cables are covered in a brush like material, which could initially be confused with dirt!! This is to clean out the pipes these cables run in. Mine seized, due to age, a water leak and lack of lubrication. To replace these, you need to remove the roof lining to get the sunroof cartridge out. Once it is out it is relatively easy to replace the cables, and possibly the gear if that is worn too. Its a good oppertunity to clean it all up and re-grease the bearing slides. Also an ideal time to give your roof lining a proper clean. I replaced my sunroof seal as well, which although not cheap, proved a worthwhile investment, as it totally cured my water leak. It also looks nice and new now. If you need more detailed info let me know.
HTH
Roo
@S2Roo: How much was the roof seal? Was thinking about replacing mine.Irvin
'08-'0?:
'01-'08:
www.irvinduguid.com
The sunroof control is built into a double relay along with the electric window control. Position 5 & 6 in the realy board under the drivers side of the dash.
Benthe best intentions are fraught with disappointment - gil grissom
Originally posted by s2avantThe sunroof control is built into a double relay along with the electric window control. Position 5 & 6 in the realy board under the drivers side of the dash.
BenWas a '93 3B, Dont ask now tho......
