Oooh thats annoying... bet some wazzik with a towbar ?
Good advice here - strip out the inside trim so an experienced bodywork man can look at properly - plus it will save you time & labour.
Because of where it is and that kink on the shaped section I will be amazed if it doesnt need paint, but being down in that corner it should be possible to get a tidy repair done that blends in nicely.
Get as many quotes as possible would be my advice... unless you know a wizard body man that doesnt charge the earth.
