My front bumper has been bugging me recently - it seems to sit lower than it should be maybe 8-10mm - so there is a gap between the top of the bumper and the headlight trims, and also the bottom of the bonnet, arrowed in this pic.
I can see the bottom mounting lugs for the headlights in the gap. Seems like it's not supposed to be like that so i thought there must be some more adjustment in the mountings behind the fogs. Had a look and they were already up as high as they could go so i whipped the bumper off and modded the brackets to extend the holes so i could move the bracket as high up as it would go, limited by the lip on the chassis leg.
So you'd think now I would have enough adjustment to get it perfect, but you'd be wrong
Its still not enough to make it look as tight as the factory pictures.
So the question, does the plastic in the bumper sag over time? Is there another variant in the bracket that is specific to the S2 bumper? (Since my car is a CQ and still using what it came with) Is there anyother way to solve this without having to fabricate my own bracket?
Anyone else got this problem? Seems odd
Its still not enough to make it look as tight as the factory pictures.So the question, does the plastic in the bumper sag over time? Is there another variant in the bracket that is specific to the S2 bumper? (Since my car is a CQ and still using what it came with) Is there anyother way to solve this without having to fabricate my own bracket?
