How to change the ignition-barrel?
  • AudiRS
    • Jul 2006
    • 159
    • Country: Norway
    I need to change the ignition-barrel on my 20v.
    I`ve taken out the stearinglock-mechanism but I don`t know how to get the old barrel out.
    Any help please?
    - `95 Audi S2 B4 2,2T Avant
    - `07 Audi A6 C6 S-line Lim.
    - `96 Audi A6 C4 2,5TDIs Quattro
    - `93 Audi 80 TDI Avant
    - `89 Audi Coupe 2,3E 20v quattro[/URL]
    - `99 Audi A4 B5 1,8TS 20v quattro
    - `92 Audi 80 B4 2,3E 10v quattro
  • Tonks4x4
    • Nov 2005
    • 3062
    You have to cut a slot into the aluminium casing so that you can push a pin to release the barrel. I have some pictures somewhere where I have done one, I will try to find them for you.
    Audi Nut!!!
    • Nuvo
      • Nov 2003
      • 3825
      Lock cylinder, removing/installing
      Removing
      1. Remove steering lock housing
      2. remove ignition switch
      3. drill steering column housing with 3 mm drill according to illustration
      a = 9.0 mm
      b = 12.0 mm
      CAUTION!
      Do not drill too deep or lock cylinder will be damaged.
      4. insert ignition key into lock cylinder
      5. push down retaining spring through hole with mandrel
      6. remove lock cylinder
      Installing
      1. insert key into lock cylinder
      2. insert key with lock cylinder into housing in OFF position
      • Tonks4x4
        • Nov 2005
        • 3062
        Thanks NUVO that is pretty much exactly what I did lol
        Audi Nut!!!
        • saltinot
          • May 2004
          • 1946
          Here's the sticky from the "Guides and Top-Tips" section with plenty of pictures to get you on your way.
          How to replace ignition cylinder / barrel FAQ
          • AudiRS
            • Jul 2006
            • 159
            • Country: Norway
            Thanks guys, this worked just fine!
            Tumbs up!
