After a bit of investigation to try and seal the windows of the front doors I discovered that both of my guide pins for the window on the passenger side are corroded. One is broken, I can't confirm the other until I remove the whole assembly.
Note: parts 27 & 28 are different and don't have part codes stamped on them.
Note: parts 25 & 24 are different and don't have part codes stamped on them.
