URGENT: Window Help!
  • Dan
    • Jun 2008
    • 1242
    What's the quickest way to get an electric window back up if the switch is doing nothing? Don't care if it doesn't work long term... just need to get it up now, before the scallys jump in my car and nick/burn/trash it!
    1993 ABY Coupe | BMW R1200 GS
    A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
  • Al Wyn
    • Nov 2006
    • 3746
    Switch swap from the good window
    S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
    • Dan
      • Jun 2008
      • 1242
      Unfortunately there isn't a good window.
      It's both windows that aren't working so I suspect the relay. I can get a new relay if that is the case, but that ain't gonna happen before it gets dark and the chavs come out
      • irishs2
        • Apr 2009
        • 2455
        Yep, I just took the relay out and tapped it upside down on the ground and then put it back in. Its been working fine since.
        Its behind the parcel shelf and is the big double relay, I think it looks like this.
        Eric
        95 S2 Avant under rebuild.
        • Dan
          • Jun 2008
          • 1242
          Great - I'll try that. Thanks!
          • prj
            • Mar 2010
            • 6308
            • jade
              • Jan 2005
              • 1811
              I have found that when my windows fail it normally the switch try swapping contacts for the other switch to get it up
              RS 2 580HP
              • Sonic
                • Jul 2006
                • 5514
                Last time my failed it was the motor getting chewed up, had to take it all to pieces.
                S2Forum.com Administrator
                • Dan
                  • Jun 2008
                  • 1242
                  @prj
                  Got it now - cheers guys.
                  I took the parcel shelf out and was looking around for ages trying to find the 343 relay. After a while I decided to then look on the layout diagram stuck to the inside of the shelf. Turns out the "random bit of circuit" I'd spotted earlier was in fact the 343 relay - just missing its cover.
                  I'm guessing someone has had trouble with this one before.
                  Anyway, cleaned up, given some physical motivation, seems to be working for now.
                  Probably best ordering a new one... and not using my windows until I have it.
                  Of course, the whole affair would have been easier if:
                  • I didn't have to do it in the pub car park.
                  • The beer garden wasn't being used for a particularly loud children's party.
                  • I didn't hate children and find their noise-making unbearable.
                  • BrianSmith_S2
                    • Jun 2005
                    • 1342
                    • Home: Northern Ireland Current: British Antarctic Territory
                    Originally posted by prj
