Avant boot grip breaks
  • tscheel
    • May 2009
    • 222
    • Country: Denmark
    I just broke my third boot grip in my second avant - I don't think I'm being very violent - have anyone else experienced this - maybe even found a repair method? It's the thin aluminium going through the holes in the door that breaks, så I don't think there's much room to spare.
    Cheers, Torben
    '94 B4 Avant S2
  • spink
    • 4382
    its a very common failure on 80 avants so its not your fault,its quite often the 1st thing to sell on a car in a breakers yard as i have always had trouble getting one when in the same situation.I havn't looked into how it could be fixed myself.
    • tscheel
      • May 2009
      • 222
      • Country: Denmark
      OK - thanks. It seems that the A6 C4 part is P&P :
      1. Die Verkleidung am Kofferraumdeckel lösen. Der Griff ist mit 2 Schrauben befestigt, der Rest nur gesteckt und durch leichtes ziehen sollte der Deckel leicht weggehen ! 2. Dann die Lampen mit Fassungen durch drehen, herausnehmen aber am Kabel hängen lassen. 3. Auf jeder Seite je 4...
      Cheers, Torben
      '94 B4 Avant S2
