rear light seal
  • bilko0795
    • Feb 2011
    • 1883
    rear light seal
    Hi guys iv got a leak in the o/s rear light i have taken the rear light off and the seal was damaged in the process what i need to know is. Is the seal supposed to be a rubber one or of a stickey type of mastic the car had a rear bump on the o/s some time in its life so there might of been a repair to the light because the seal was of a sticky mastic type i don,t want to take the n/s off to check just in case i damage it iff its the stickey type. On ebay there is a rubber neoprene seal that fits ur Qs and also coupes would this be any good?
    cheers.
  • johne
    • Apr 2007
    • 1405
    The "seal" is the sticky type mastic you found.
    If you've got water coming into your rear light and it's a coupe check it's not getting into the back of the unit.
    The self tapping screws that hold the plastic trim down that runs across the bottom cill of the hatchback openning often let water leak past them and one of them happens to be directly above the back of the lamp unit. I got water in my lamp unit thinking it was getting in past the mastic seal, replaced the mastic only to find out the water was getting in to the back of the lamp as I've described.
    John
    • AndyP
      • 6049
      You can buy the seal from Audi but it comes on a huge roll, so you need a friendly parts guy who will sell you a metre or two. I use this:-
      http://www.frost.co.uk/automotive-bo...-compound.html
      Just roll it into a long thin bead in your hands, and it's re-usable.
      • bilko0795
        • Feb 2011
        • 1883
        Thanks for the info guys the water must be coming in from the lamp as its really wet on the top of the lamp and the water as got to the black connecting plug for the bulb holder and is playing f--k with the electrics and the holder pins are all rusty i will have a check of the screws and replace the seal.
        Cheers.
          water also leaks in through the mounting holes for the ridged black tailgate trim piece, worth a look
