My '93 B4 Coupe has a boot full of water!! I lifted the carpet and at the front right hand side, the plastic container under the carpet was full of water (also explains why the car's forever misting up!)
It looks like the seal where the boot lid shuts to the bodywork has perished as there's a chunk of the inside bit missing. If I just replace the seal will this likely fix the issue or is there a known problem as well that I should look for?
