3b and aby radiator covers difference
  • aronmatic2
    • 2129
    • Country: Hungary
    anybody know about difference between 3b and aby(adu) radiator plastic cover?
    Real carbon parts for S2 and RS2. Check Carbondesign on facebook
  • simon20vq
    • Dec 2010
    • 1379
    I have one on both and don't recall any differences. Its even the same on the 90 20v I have.
      the B3 ones are definitely different as the slam panels are different, I had to use an ABY one when I put the B4 front end on my car, not sure about 3B Vs ABY
      • mcandmar
        • Apr 2004
        • 5118
        Only difference i know of is ABY models have a guard over the PAS pump pulley, where as on earlier cars the guard was part of the alloy mounting bracket for the pump.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
          ahha maybe I have a 3B one then.... I will take a pic of both of mine for reference
          • aronmatic2
            • 2129
            • Country: Hungary
            thanks for that.
            • simon20vq
              • Dec 2010
              • 1379
              You learn something new every day
              • mcandmar
                • Apr 2004
                • 5118
                Sorry ignore that, just had a look though a few pics and the 3B has it too. I could have sworn it was different.
                However i did notice a difference on the right hand side, early B3 and 3b's had a water tank next to the rad where as ABY is inside the wing. So basically the ABY one is larger to cover that area. B3/7A looks different shape, but the 3B and ABY look the same apart from the right hand corner. I bet you could just make ABY versions and trim them to fit 3B's.
                  Here we go, 7A one on top (893 121 293), 3B/ABY (8A0 121 293) on the bottom.
                  There are subtle variations in shape that means the 7A one does not fit the B4 slam panel
