Water behind drives seat
  • tomwood_uk
    • Feb 2009
    • 336
    Hey guys,
    Its about this time of year I get loads of water on the floor mat behind the drivers seat if it's been raining. I'm gonna have to have a good look into it, but what do you guys think is the most likely cause? Door seal?
  • shaun5
    • 1610
    There are a few options, Fuse box not sealed correctlly or maybe bonnet pull cable gromet damaged/missing. like you have also said door seal.
      Do you have a sunroof? If so the four draintubes need to be cleaned with the plastic "string" from a weedwacker.
      C4 drain example but similar for ACOQ and A80Q etc. Items 3.
        a few options:
        bonnet pull cable grommet
        door seals
        sunroof drain tubes
        windscreen area - has this been replaced before? If so this is probably the culprit. Loads of threads on this:
        HTH
        • tomwood_uk
          • Feb 2009
          • 336
          Thanks gents,
          Yes the car has a sunroof (its a coupe). I have noticed that the seal on the sunroof is slightly pushed in where the two loose edges meet. Where do the drain tubes drain to?
          To be honest the windscreen is in pretty poor condition. It is discoloured along the edge of the drivers side. The water problems are most likely a combination of different faults so I'll have to work my way through them.
            Originally posted by tomwood_uk
            Thanks gents, Yes the car has a sunroof (its a coupe). I have noticed that the seal on the sunroof is slightly pushed in where the two loose edges meet. Where do the drain tubes drain to?
            The drains start in the four corners of the sunroof cassette, i.e. that you can see at the front and two that are way back in there. The front ones drain down the A-pillars and come out at the bottom of the front wings/fenders. The rear two go down the C-pillar and come out behind the rear wheels, behind the rear wheel well liners. You need to used the weedwacker plastic "string" from the top side, within the sunroof cassette.
            • QuattroFever
              • May 2006
              • 1360
              Another problem is the black plastic/metal? Trim that is pop rivetted to the frame works loose and leaks water running off the roof round the back of it and runs down inside the door seal.
              Volcano ABY coupe
              Ant
              • benntenn67
                • Jun 2009
                • 859
                I might be wrong but I thought the rear drains on a coupe ran into the tailgate opening ??
                Audi S2 Coupe 1995
                VW Passat GL5 (hatch) 1986
                VW Passat GL 1.8 (saloon) 1986
                Carrera Subway 8
                  Maybe. Get a spool of the grass trimmer (weed wacker) plastic "string" and push a length off the spool down the rear sunroof cassette drain hole and see where it comes out.
                  • bluequattro
                    • 2960
                    No, do the sunroof drains with an old speedo cable, much stronger if gunged up and still flexible
                    One of my a4 turbos used to fill footwell with water, was bonnet pull grommet missing
                    • benntenn67
                      • Jun 2009
                      • 859
                      I'd proceed with caution though as it's easy to pierce or push the pipe off - I would have thought that a blocked sunroof drain would leave a damp patch on the headliner??
                      Audi S2 Coupe 1995
                      Carrera Subway 8
                        Sure, if you have an old speedo cable and it is long enough. Otherwise, my suggestion is workable.
                        • bluequattro
                          • 2960
                          Don't force it, screw it in gently same direction cable is wound
                          Oo, sounds a bit rude does that
                          • tomwood_uk
                            • Feb 2009
                            • 336
                            Cheers for the advice guys. I'll see if I can have a bash at the weekend weather permitting.
                            Seems to be a common problem with these cars by the looks of it..
