Cleaning and painting front grille
  • Ian Simmonds
    • Jun 2005
    • 2858
    Whats the best products to clean a road grimed S2 front grille ready for painting black? I've done it several times with Ur grilles over the years with okay results, but I'd like to do it properly and dechrome it.
    Kind regards
    Ian
    93 MTMS2 Avant
  • dest
    • 4287
    The best way to dechrome it, is to literally remove the chrome!
    I did my old S2 one, just used a very sharp knife and carefully get a bit started and work your way round
    You are left with perfectly smooth plastic to laquer (use the correct plastic one obviously) and it will never chip
    (Should be a photo showing above, but photobucket seems to be playing up )
    • s2_wot
      • Aug 2006
      • 2178
      Shane
      • Ian Simmonds
        • Jun 2005
        • 2858
        Ooo, thats good to know, many thanks.
        What did you clean/ prep it with before you painted it with elastised paint?
        93 MTMS2 Avant
        • dest
          • 4287
          Just gave it a wipe with a damn cloth!
          You could near enough paint the black straight onto the plastic, its perfectly smooth, but I didnt want it to peel
          • Sleeper_Avant
            • 2372
            i used red scotchbrite, 5 coats of plastic primer and 5 or so coats of satin black (dont use cheap halfrauds crap paint or similar)
            results were good,
            you are just aiming to key the surface to accept the paint, i.e making it "dull" all over
            1993 URS4 Avant Emerald Green 350+bhp
            1991 Ford Sierra Sapphire 4x4 in Magenta
            BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
            • Ian Simmonds
              • Jun 2005
              • 2858
              lol... Okay-doakes... Its the road grime I was worried about kn@ckering how the paint adheres to the rest of the grille... That, and being lazy at scrubbing the dead flies off...
              93 MTMS2 Avant
                Scotchbrite is your friend
