Replacement head light fixings
This is a sticky topic.
  • Acidburn
    • 13459
    its around a 10 min job.
    Get a non ellipsoid headlight and pop the 7 or 8 metal tabs off and remove the glass (the seal might be stuck on so be gentle)
    remove the level adjuster/fixed adjuster and the side repeater bulb
    pop off the silver outer section of the light thats just a push on trim
    then using a 10mm ratchet with extension start undoing the two adjusters on the back (some are already knackered so a pair of grips to wind them out works)
    remove the two spade connectors remembering which way they go
    then using a big pair of mole/vice grips pop the plug for the power/etc connector to the light it just twists and goes inwards.
    You will be left with
