My grill was fitted with 3 self tappers, a wing and several prayers. Now I've bought the 7 clips from Audi Tradition, please could someone tell me how they fit on? Do they need screws to go through them too? If anyone had a photo that would be great, thanks!
Grille fitment RS2
I will open by saying that the RS2 grill clips are ****ing ****!
Probably the worst idea by Porsche since they stuck the engine in the wrong end of a sports car.
Yup you need some nice stainless pan-head screws to tighten the clips onto the frame tabs.
I will try and take some pics of mine later
Imola B6 S4 Avant -
I need some of these clips!! where can I get them from or is there something that will do the job??sigpicComment
Gents,
They need screws for sure.
I recently replaced mine, the problem is they are made of spring steel and corrosion occurs at the points where they bend (does that make sense !), they loose their spring properties and become useless... If the grill is loose then this is likely to be the problem, but be careful, once you take them off, they WILL dissolve in your hand.
To make them last a bit longer, I dipped mine is a rust preventing solution (rust killer), then let them dry. I have also heard people give them a coat of other paints etc...
Definitely use something as they are a weak point...
PAULComment
Not a bad idea painting or dipping them in rust killer.
Sent from my iPhone using TapatalksigpicComment
The RS2 grill clips are rubbish, as Alex says their probably the worst thing Porsche has designed, I gave up trying to get mine to fit properly and sold it on.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
Yeah, some pics would help. Not sure I've done the right thing getting this grill.... 😕
