does anybody know the best way of doing this ie, where the rivets are etc as i have Arons carbon goodness to put on!!!!!!!!!!
B pillar outer trim removal
mate those carbon ones slot over the top with double sided tape. easy job its just get the best double sided tape you can and i heated it up to help it adhere. -
ABY Cricket Green Pearl Coupe, blk leather
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!Comment
they do. have a look on arons website.
also i have them on mine. if you remove the original it leaves a huge void so there's nothing to attach the carbon one to.
it is purely a cover. they don't affect the door closure on mine. the only thing i found was that the window seal is rushed out slightly.
my passenger side one fits like a glove but the drivers side one sits slightly proud at the top?
i came close to taking them off because of this but i recently used some very good tape and warmed the cover in the oven at 90 then fitted it its fitted perfect since.Comment
whay tape did you use? i was thinking of using windscreen mastic, have you any close up pics? did you have to trim them at all? as i`ve tried a test fit and they sit quite proud at the top
cheersABY Cricket Green Pearl Coupe, blk leather
Mine are complete replacements, I had to drill the rivets out.Comment
I told you mate, its have to glue up to the original. I try to find some How-t pics, but my hard drive died. Its very easy. Its will fit very nice. You can use some kind of hard double side tape, or windshield glue.
its will be looks like this:
Real carbon parts for S2 and RS2. Check Carbondesign on facebookComment
i found the passenger one fits perfect but the drivers side kept coming away at the top at the rear. in the end i used mammoth tape and put the whole thing in the oven at 90 for 10 mins. it came more pliable and stuck well. only problem is there is a couple of tiny fractures in the finish from having to be messed with so much. other than that they look goodComment
i might have to try mine with some of that then. drivers side one won't stay put and keeps peeling away at the top and its starting to get little cracks in the top coats . well done mate.Comment
eBay is your friend there is various types will have a look which mine is when u get home and edit with which it is
its sikaflex 255fc
Sent from my iPhone 5
using TapatalkLast edited by vonbeck; 6 March 2013, 12:22.ABY Cricket Green Pearl Coupe, blk leather
