C4 Outer Taillight Replacement DIY
    I had to replace the right outer taillight on my 98 C4 avant with the BOSE subwoofer jammed in the cubby so I took a few photos for fun and wrote up the DIY linked below. Probably a no brainer but hey sometimes reading a DIY gets you through a period of head scratching with less hair loss.
    Enjoy (Probably very similar for S2s and RS2s):
  • bluequattro
    • 2960
    No brainer that's true
    But can you do it from inside without opening the bootlid?
    I had to remove one like that at the scrap yard
      Originally posted by bluequattro
      No brainer that's true. But can you do it from inside without opening the bootlid? I had to remove one like that at the scrap yard
      That sounds like a challenge all right.
      • bluequattro
        • 2960
        Sure was, doors from another car I'm the back too, wouldn't fit through side doors and tailgate against a wall hence not opening it
        But a pair of tail lights a manual and a load blind for £20 was good enough
