Help to remove sunroof
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    Hi i need to remove my headlining so i can swap over the cardridge. Ive not done this before due to my sunroof opening on the ****, it doesnt slide it goes to about an inch then stops, so does anyone have a write up on how to remove? cheers for the help, pics too please thanks
  • andyg plym
    • Nov 2006
    • 4646
    Remove grab handles, at top of windscreen there is a rubber window trim
    I start from the rear of the car it has some poppers from what I remember
    P.s got back at 1am !
    • nip
      • Apr 2006
      • 1786
      Cheers Andy , lol bet ur shattered now
      • Acidburn
        • 13459
        remove grab handles
        remove trim at back of boot
        remove sunvisors (2x screws under cover on sunvisor and 2x on the holder clip but be careful, these break VERY easily) and unclip the electric plugs
        remove sunroof switch panel
        remove rubber at front of headlining
        pop down the metal surround for the sunvisor
        remove a/b/c pillar trims
        use hand to push down the headlining as its glued up
        take out thru boot of the car
        remove the sunroof cartridge whole by undoing all the 10mm nuts/bolts
        pull the drainage pipes off
        worthwhile changing the sunroof seal whilst doing all this, £67 i think last time I got one for my white car.
        • nip
          • Apr 2006
          • 1786
          Cheers Pete
          Right I took the motor off and caked the cables in wd40 it now goes back and forth, it does stick but all I do is take the motor off and cake it in ub40 again lol , the only snag was it pulled the sunroof lining off on the one side, I need pics of an avant sunroof fully open if anyone could take some please, cheers
          • rj scotty
            • May 2006
            • 2195
            will sort in morning
            BUT I DON'T WANT A NEW CAR!
            1995 S2 Avant, Volcano Black
            • Acidburn
              • 13459
              I think wd40 will be better than caking it in ub40
              the sunroof trim is a pita to do, its got two metal pegs at the front that holds it in and from what I remember some velcro or something at the back that holds it on.
              • nip
                • Apr 2006
                • 1786
                Lol, I read up someone using a syringe and filling it with ub40 and injecting it through the cables, for the lining I got some super super carpet spray which I hope works
                • nip
                  • Apr 2006
                  • 1786
                  Cheers richy
                  • kulster
                    • Sep 2007
                    • 290
                    Ill give you a hand, just bring it over to my work in Birmingham and I have all the tools
                    • nip
                      • Apr 2006
                      • 1786
                      Cheers kulster, thanks for the offer but I'm off got to do a few things around the house , cheers again for the offer
                      • rj scotty
                        • May 2006
                        • 2195
                        • nip
                          • Apr 2006
                          • 1786
                          cheers rich spot on!!
                          • nip
                            • Apr 2006
                            • 1786
                            Removed the headlining, on the cartridges how do i remove the sunroof panel itself, im thinking undo all the screws then what? hope someone can help please
                              As Pete's reply earlier in the thread!
