How to remove wing badges
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    Hi all i want to remove my wing badges on my avant, is this possible without taking the wings off? cheers
  • mdz
    • Jun 2012
    • 775
    • Country: Latvia
    Easiest way is to use flat screwdriver and pop it off. If you want to completely avoid damaging paint, take out inner arch liner and push badge out from inside, badge has two pins holding it through wing.
    • nip
      • Apr 2006
      • 1786
      cheers mdz
      • RustyNut
        • 1433
        • Home: Zambia Current: United Kingdom
        The badges either have two pins which locate in to a plastic sleeve or are stuck on with a double sided type foam tape. If you intend to remove them layer the painted area that you are going to lever off with masking tape to avoid damage and select your tool wisely and be gentle..!
        Old Stuff Reborn.
        • RustyNut
          • 1433
          If they're stuck on with foam tape use fishing line to cut through the tape. This works well on number plates too.
          Old Stuff Reborn.
          • nip
            • Apr 2006
            • 1786
            Cheers rustynut, just done it it had 2 pins , I might even remove the carbon canister while I'm there
