floorpans, B4 80 saloon
  • @ndy
    • Sep 2012
    • 205
    morning guys,
    Just wondering if someone could confirm something for me.
    Is the floorpan of the B4 saloon the same between the FWD and Quattro?
    meaning, could I put rear diff, prop, etc from a Quattro into my FWD 80 and convert it?
    My friend has a written off s4 he's bought for body panels, this leaves everything mechanical available, which he's offered me at mates rates.
    Must admit, I'm tempted!
    The car is a daily but I car share so can afford the car to be off the road for a few weeks. Also fairly handy with a set of spanners, I've done a bit of welding before but have mates thats are sh*t hot at it, would get the exhaust's fab'd at a proper exhaust place tho.
    Any advice, besides 'don't bother, just 1.8T it'.
    I'm also thinking of that too as it's going to be alot easier.
    Cheers,
    Andy
  • mdz
    • Jun 2012
    • 775
    • Country: Latvia
    Body is the same for fwd and quattro. There's only 2 threads and few brackets that needs to be welded on from donor car
    • irishs2
      • Apr 2009
      • 2455
      Its possible. Acidburn did it with his tdi quattro thats now broken.
      You need a B4 quattro fueltank too.
      Originally posted by Acidburn
      Its not quite as straight forward as his thread, biggest issue was he didn't have the fuel tank to worry about as he had a fuel cell (from what i remember)
      You need to find the two mounting holes under the sealent at the back.
      Either make or cut the diff bracket off a quattro and remove the spot welds then weld into the new car then do the prop bracket as well.
      There is quite a few other little changes, a lot of the mounting studs for shields etc I had to grind off the car.
      b4's are possible to change to quattro but not coupe's as the floor pan is different.
      If you want a stock looking car then you would need a quattro b4 fuel tank. The a4/b5 fuel tank will NOT fit as the filler neck is more towards the front of the car than this style car.
      You would either need to fab the brackets or cut them out a quattro car for the diff mount and the prop. Then its the usual stuff like the brake lines different and only one going to the rear rather than the two on a fwd, the abs wiring is different as well so i'm putting the complete loom from an s2 avant into the car soon.
      Basically I think you will need a s2 avant or b4 quattro , to take bits from to make a b4 quattro... lol
      Eric
      95 S2 Avant under rebuild.
      • Acidburn
        • 13459
        differences i found was:
        you need the bracket welding on at the front to hold the nose of the diff up
        prop brackets
        80/s2 quattro fuel tank an s4/a4 one will NOT fit
        the mounting holes for the subframe are all there so thats a quick an easy job (edit - there is 2x holes with no thread inside, all me and error404 did was take a subframe bolt and find a decent nut with a shoulder, turn it upside down and insert it into the hole which is already there and weld this in so the subframe can be bolted in)
        the abs sensor wires are different but apparently you can cut/solder the two together and make them work
        you only have 1x brake line that goes front/back unlike your current setup as it splits on the rear subframe rather than just two lines
        exhaust is different
        you have to grind off a couple of old heatshield mounting studs which is a 2 sec job each
        at the front there is a bracket for the stock gearbox, this needs cutting out which is not too hard then swap to a 5/6 subframe at the front.
        if you need anymore info or parts I have the bracket for the diff already cut out a car, a fuel tank, basically i can have everything to do this conversion quite easily.
        • @ndy
          • Sep 2012
          • 205
          Cheers for the advice Acidburn. Do you rekon you'd be able to do a quattro conversion on a weekend?
          • Acidburn
            • 13459
            if you had access to a ramp/welder and the bits then yes it would be possible.
            Either that or you could bolt up the complete rear setup after welding in the diff bracket and run it around for another week as fwd still but with a quattro rear end.
            • mdz
              • Jun 2012
              • 775
              • Country: Latvia
              ...nut with a shoulder...
              Something like this?
              • shaun5
                • 1610
                Why not just buy my B4 80 quattro bodyshell
                  That is what we used initially, but actually afterwards we thought it probably needed reinforcement so we cut it out and drilled a hole in a 3" disc of sheet steel, then welded the nut to that sheet then welded the disc to the chassis
                  I would be interested to see what reinforcement is inside the chassis box section of a quattro car, as i think there is more to it than just a captive nut on the back
                  • mdz
                    • Jun 2012
                    • 775
                    • Country: Latvia
                    Thanks Error
                    I'm also planning to do this swap later and was wondering what others did to add threads.
                    • Sleeper_Avant
                      • 2372
                      i might have a £100 quattro, fully panneled with glass bodyshell with MOT if interested
                      rare car
                      • @ndy
                        • Sep 2012
                        • 205
                        where abouts are you sleeper?
                        • Sleeper_Avant
                          • 2372
                          Essex, innit bruv!
                          i might be breaking the car so let me know if your interested ok
                          • @ndy
                            • Sep 2012
                            • 205
                            Sleeper, you're a bit far from me but I've got mates from Essex so might be able to arrange collection round a visit.
                            • Sleeper_Avant
                              • 2372
                              cool, as per PM, if i break it shell would be scrap price at £100
