can see this going on a while lol
rs2 wing mirrors?
You got to remember we have clocks older than Canada. So this leads me to think we are correct
Also the wing mirror ( fender) is because you can see your rear wing.. Made that up..
An the view is pants
I can't put my finger on it, maybe it's not the mirrors but I reckon visibility to the rear is one of the worst I have had on any car, then again I haven't owned any other Avants/Estates...could well be that?
From what he's saying Pix has the same 'view'....Comment
Hi Martin,
could you describe what makes lhd vs rhd rs2 door mirrors different physically? I've done a search that never actually revealed the difference other than opinion. In that search someone had mentioned that switching rhd and lhd driver mounts would yield better angle on the mirror housing for greater visibility.
Cheers mis amigos,
_AntonComment
As said, the RS2 mirror bases are unique to the RS2. Anything else is a bit of a bodge.Hi Martin,
And yes. The housings are different between LHD and RHD.
Sit in the passenger seat, then try to adjust your mirrors as if you are the driver, then you will see the issue.
I find with teardrop Porsche mirrors they need to be adjusted perfectly to ensure good visibility.
The horizon needs to level with the widest part of the mirror, and the car body side should only just be visible on the inside edge.SSComment
I'd agree with that. It is possible to get convex mirror glass from Porsche from the 993, has anyone tried them to see what that's like?Comment
