Front bumper washer jets advice ?
  • R5T
    • Jul 2012
    • 250
    Afternoon all,
    I'll keep it simple, is there a particular way to fit s2 washer jets to a "non washer jet" v6 bumper ? Obviously I will have to cut a hole out but what I meant to bolt them to ? Has anyone done this before ?
    Any advice appreciated,
    Sam
    93' Audi 80 2.6 Quattro
    93' Audi Coupe 2.6E Auto
    90' Audi Coupe 2.3e 10v
    95' VW Polo 1.0 ...
  • mdz
    • Jun 2012
    • 775
    • Country: Latvia
    Jet bolts on using metal plate from behind. Part nr. 5
    I've done this but have no pictures from process.
    • Louie C
      • Jun 2012
      • 288
      Originally posted by R5T
      Afternoon all,
      Sam
      Can I ask why you want to fit the washer jets? IMHO it looks better without, and unless your running HID's then I dont really see the need?
      • R5T
        • Jul 2012
        • 250
        I haven't got HIDs and I'm doing it purely for cosmetic, I like the way they look, and want to have a S2'd B3 front end, I have done the bumper and have a decent look mesh grille. So like I said, purely cosmetic, I like the way they look.
        Sam
        95' VW Polo 1.0 ...
        • Monkeymagic
          • Mar 2012
          • 3419
          They are held in by two 10mm nuts. Simple
          • R5T
            • Jul 2012
            • 250
            Yeah I have the two 10mm nuts for each jet but there is nothing internally for them to bolt on to will be looking for the metal plates/brackets mentioned above once I've sorted other bits and pieces. Thanks for the help guys.
            Sam
            95' VW Polo 1.0 ...
            • Acidburn
              • 13459
              part 5 - either check with audi if they still supply them or just make them
              • R5T
                • Jul 2012
                • 250
                That was the plan if I couldn't get hold of them, can't be too hard to fashion something
                Sam
                95' VW Polo 1.0 ...
                • mdz
                  • Jun 2012
                  • 775
                  • Country: Latvia
                  Here's how it looks
                  • R5T
                    • Jul 2012
                    • 250
                    Where abouts or how does the bracket ate fit ?
                    Sam
                    95' VW Polo 1.0 ...
                    • mdz
                      • Jun 2012
                      • 775
                      • Country: Latvia
                      Look at the back of your bumper, holes in crossmember should be already there. You have to drill holes in bumper skin. Washer pod goes through hole and metal plate bolts on from behind. Easy
                      • LSG
                        • May 2010
                        • 897
                        Why not fit the RS2 washer jets. I think they may be a lot easyer to do and look nicer than the S2 jets. part no,s are. A8AO 955 101 GR U jet carrier £11.25 x2. A8AO 955 137 Hex nut £0.78 x2 and A8AO 955 138 Packing £11.01 x2. Good luck with what ever you do.
                        • R5T
                          • Jul 2012
                          • 250
                          Thanks for the advice and pics guys, little bit of thinking to do but thanks again.
                          Sam
                          95' VW Polo 1.0 ...
                          • YELL MAN
                            • Dec 2005
                            • 535
                            • Country: Shetland Islands
                            I actually like to look of the standard washers
                            1994 Indigo Blue S2 coupe
                            1994 80 Avant 1.9 TDI
                            2005 Yamaha Fazer 1000
                            1953 AJS Model 18S
