Coupe carbon B pillar cover fitting
    Do you need to remove the existing B pillar trims to do this? I just went to have a look and there isn't enough room between the gutter trim and B pillar trim to fit the carbon in... can't see that it's supposed to butt against the pillar trim
  • s2driveruk
    • 12696
    Yeah, they are replacements as far as i know....look great too!
    1992 3b S2 Coupe
      They're covers mate. Ended up removing the B pillar trim and getting one side on there today. Will re-do it when I do the other side, as I've learned a bit from today. I'll write up a how to when I do it, as it may help others.
      • Monkeymagic
        • Mar 2012
        • 3419
        Don't need to remove trim they just about slide under the rubber and the trim across the top. One of mine wouldn't quite sit right so used some sikaflex and bobs your fathers brother
          I think my trim had been refitted as it was totally flush. Not hard to remove and could clean up the OE cover, as it was corroded a bit.
            All done. Write-up here.
