Headlight washers stopped working
  • Graham
    • 1622
    Hi, today i noticed my washers for the headlights have stopped. There is no pump noise, or voltage drop. My windscreen washers are fine, can anyone shed any light on this problem, like where is the fuse?, is it independantly fused?, as the haynes coupe manual is (as always) a joke.
    Graham
  • jameswkr
    • 538
    They only work when lights are switched on. You will need to remove the bumper to get access to the valve if its failed. HNY James
      its worth checking the pipe to the jets, mine came off when I refitted my bumper before now.
      • s2carlo
        • 252
        Graham
        BTDT.
        I had it on my 3B coupe, which has a separate tank with pump for the headlightwashers.
        I took out the plastic part inside the wheelarch to reach the tank and it's pump. Checked whether it got power when needed, it did.
        Then I took the pump out of the tank (watch out all water is coming out ). I reconnected the pump to the electric and checked whether it would turn when activated, it didn't, it was jammed.
        I cleaned the rotary part with carb.cleaner and tapwater. Tested the pump again, it was working again. Did some extra cleaning and testing and it stayed OK. I refitted it and it is still working, half a year later.
        All in all 1 hour work.
        Succes
        Carlo
        No power, no glory!
        S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
        • Graham
          • 1622
          Excellent, thankyou and a Happy New year to you all- my head is still pounding off last lights adventures
          • porkkis
            • 1994
            ABY cars should have only one tank that is inside the arch. There are 2 pumps. Also a separate relay is used. So probably the pump or the relay is dead.
            MY91 3B cars have 2 separate tanks but afaik MY92 on only 1 tank is used.
            • Graham
              • 1622
              Does anyone know where the relay is?
              Also if possible the number on the relay, as i have a few spares.
              • porkkis
                • 1994
                It's in the fusebox.
                Probably Scheinwerferreinung something.
                • s2avant
                  • 2426
                  On the back row of the fuse box. Fourth one from the left. Doesn't have a relay number on the top (at least the brand new one I fitted last week in mine didn't).
                  Could well be the pump. My windscreen washer pump died without warning a couple of weeks back.
                  Ben
                  • Graham
                    • 1622
                    Cheers i will have a look. The mother in law (to be) is sooo gullable with these, over 5 times now, i have caught her out saying something along the linees of "have you seen the scratch above the headlight on the bonnet", and she always goes for a look where i apply the washers- Soaked every time
                    • Graham
                      • 1622
                      Today i lost my rag with the car as it cut out on me nearly every time i took my foot off the accelerator and dipped the clutch so this evening i waged war. I removed the ISV and it was bunged up solid, so washed it out with 2 cans of carb cleaner (YUK- The crap inside was bad), and oiled it up, now it doesnt miss a beat . And while i was under the bonnet i decided to tackle the headlight washer problem. Unclipped the wire to the pump and pulsed the pump off my power pack and it worked (soaking me ). So i removed the relay, read the diagram and put a supply across the activator line and nothing. So i technically battered it off the walls and tried it again, Hey presto, it works a treat- lets see how long it takes to fook up again, if it dare . So i am all working (ish) again
                      • Jas11n
                        • 5067
                        Mines doing this at the minute doesn't cut out,,,,,just drops well below it's normal idle,,,then changes it's mind and bounces back up again,,,,,,,,,,every bloody time I dip the clutch,,,,,,,,,,,,,,,,weirdly though, if I sit in traffic for a couple of minutes,,,,it stops doing it
                        ISV getting cleaned good a proper tomorrow I think
                        How's tricks Graham
                        2001 Avus Silver B5 RS4.
                        1995 S2 Coupe - sold (sniff)
                        • Graham
                          • 1622
                          Thats how mine was about 2 weeks ago, if you let it warm up in traffic it is ok but today it done my head in. Did you get the testers off Graham, i might be popping over there on Sunday as our lass has to go to a wedding convention with her mate, they wanted me to go LOL. I am fine, my calliper is on its way from america this weekend hopefully so i can get my big brakes on again. And the car other than my ISV problem is running sweet as a nut.
                          • rotoryboy
                            • May 2004
                            • 3281
                            Mine did the same, so last week I cleaned the ISV. Fab.......ran like a dream, then coming home tonight it started again Oh well better do it again
                            Mark
                            Race Clio RS197
                            S2 Coupe ABY (Green) - RIP
                            S2 Coupe ABY (Blue) - Sold
                            • Jas11n
                              • 5067
                              Did you get the testers off Graham?
                              Not seen him yet mate, I'm not doing anything on Sunday,,,,,so may have a pop over too,,,,,if thats ok with Graham of course,,,,,I'll send him a PM.
                              Got a real bad back at the minute,,,,,hell on earth pressing the clutch down so much so, I let a 180bhp TT take me tonight
                              Any idea how much a new ISV is??,,,,,,,,anyone????????
                              You going to be around on Sunday too Mark? Nice one on the brakes mate,,,,,I got those I was talking about,,,,,,just need to find the time to shoot up and get them
