My inner fenders (the plastic wheel well liner/cover) have different cracks in them. Does anyone know if there's a replacement for this? Audi doesn't have them since 2007, on eBay there are some offerings on new, but seem to generic ("Audi 80 > 1991").
The ones of the RS2 are the same as the 80/90/avant quattro. 8A0 810 171/172 B
The 80 ones are 8A0 810 171 (without the "B").
thanks. The problem with these plastic parts is that they become brittle, especially on the edges that are exposed to sun. I've seen new ones on eBay for (relative) little money, but am unsure what the quality or fitting is with these..
Just fitted a wheel well liner rear left coded 8A0810171 on my RS2.
I can confirm that it does fit as long as you cut a wider window on the suspension opening and you trim the front side where it goes under the peculiar RS2 skirts.
I'm talking about one/one an half inch cuts nothing major.
Best to look at the opposite one and make yourself an idea where and how much to cut it.
Apart that everything matches including all the screws holes positions.
