DIY wing/bumper respray: TIPS NEEDED!
  • hunker7
    • Mar 2014
    • 3487
    As I can't afford to do a full respray straight away, I've decided to go down DIY route. There are panels that need some attention due to rust, such as wings, and bumper is all faded. I've done some research and it turns out you can get decent quality with using electric spray guns.
    As my experience with painting are domestic, and spraying calipers , I have some questions and some things that I just want to check if I have the right idea.
    Wings have some lacquer peeling off, so should I strip panels down to bare metal?
    I did some reading about primers, base coats etc.
    So, the order would be:
    Self Etch primer first, then high build primer with some wet sanding to make panel smoother then 2-3 of base coat and then 3-4 clear coat?
    I can't seem to find anything useful on polishing once clear coat has been dried, any suggestions?
    Tips and suggestions appreciated.
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
  • bluequattro
    • 2960
    http://ds23pallas.hubpages.com/hub/P...with-cellulose
    May be useful.
    I've bought a compressor and intend to paint some parts for my tdi.
    I'm going to a friends body shop this week to get some of his left overs paint.
    I've a few old panels that I'm going to work on before doing important panels.
    I've not seen good results with an electric gun
    • hunker7
      • Mar 2014
      • 3487
      May be useful.
      Thanks. I will probably take door off A100 and try on that first, just to see how it goes. What I like about electric spray guns is there is almost no overspray, and I don't have access to a big space, otherwise compressor and spray gun would be the obvious choice.
      '93 Audi UrS4 Avant
      • bluequattro
        • 2960
        I'm going to buy a gazebo and spray in there
        • hunker7
          • Mar 2014
          • 3487
          That's a good idea actually. If i do go down air route, what sort of guns should i look at, there are guns for 20 quid upto hundreds. Thanks
          '93 Audi UrS4 Avant
          • bluequattro
            • 2960
            Dunno! I'm new to spraying too. A cheapo gun came with my compressor, so I'm practicing first with that.
            I have a mate that's been spraying for years, he s going to teach me how to set guns up.
            I've also bought an airbrush to do detail work (and the wife wants flames on her vw van!)
            • hunker7
              • Mar 2014
              • 3487
              Another reason to go for electric, in my case, no setup needed. I feel like if i go air route I'll just waste money and get nothing done or finish will be horrifying.
              '93 Audi UrS4 Avant
                • 4754
                Get a Devilbiss!! The best.
                • hunker7
                  • Mar 2014
                  • 3487
                  Those guns are steep
                  '93 Audi UrS4 Avant
                    • 4754
                    Good job i still got mine then. Mine is no longer available a JGA 558 with (30) cap as i sprayed 5 cars with mine in solid colours last one in 1996. Its great to do your own so you can control the quality but with all the consumables it really adds up to a lot so not really a good idea unless you plan to do several cars.
                    • pasbogdan
                      • Sep 2009
                      • 1160
                      • Country: Romania
                      Do not waste money on things and try to do it on your own.You will regret it.
                      Also do not try to waste money on quality tools.If you are not experienced the result will be bad and it is a time/money waste.
                      Do what you do for leaving,get the money,get the rust blasted(sand,ice,soda etc),get por 15 on it and paint it at paintshop.
