Windscreen Restoration
    In an attempt to put off replacing the screen, is there a way to polish it back to some sort of decent state? The 'screen on the old girl is looking very much past its best...
    Other than that, I'll have to take the plunge, remove all the trim that I've finally got sealed and leak free and start again... which I'm highly non-keen on doing.
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    What's the problem with your screen, is it mostly chips or scratches? I've clayed mine and it's made a difference but yet to machine polish it (I do have some thin microfibre pads so I can polish it). Yet to have a go as I'm not sure on the proper technique for polishing glass yet but I am sure this can be done
    1996 S2 ABY Silver
      I'll try the claying first.
      It's covered in light scratches and dints.
      • quattrostyle
        • Oct 2006
        • 6229
        Something like this? https://www.youtube.com/watch?v=emvl30wsoF0
        although I still see a part of the scratch at the end of the vid.
        And this: http://www.detailingworld.co.uk/foru...d.php?t=153788
        • orsum
          • May 2010
          • 1213
          • Home: United Kingdom Current: South Africa
          Why not just replace it?
          orsum
          • vonbeck
            • 2455
            If the laminate has gone\ is going your better of replacing it
            Sent from my iPhone 5
            using Tapatalk
            ABY Cricket Green Pearl Coupe, blk leather
            THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
            • mike74
              • Apr 2014
              • 615
              Sounds like you need some of this stuff
                orsum
                Because I've got it leak free for the first time in my 10 year ownership and the cause of the leaks? A botched windscreen replacement (trims etc.).
                If I find an OE Audi glass and did all the trim removal and refitting myself, I'd consider it but for now, I just want to put a plaster on it, rather than remove the whole thing.
                If I do get the windscreen replaced, I've also got to get the rust on the leading edge of the roof sorted, again more than likely started by damage caused by the last windscreen...
                The current windscreen is fine in all but direct sunlight... so I caould just drive it at night
                • rj scotty
                  • May 2006
                  • 2195
                  I'm in the same situation. Ill try claying it and a rotary buff with G3
                  BUT I DON'T WANT A NEW CAR!
                  1995 S2 Avant, Volcano Black
                  • orsum
                    • May 2010
                    • 1213
                    Sort the rust Rusty
                    Audi stock item.
                    Plasters are good but they dont last.
                    Leaks are a problem I am told I only hope when mine comes back to is leak free.
                    There is a glass polishing compound called CERIUM OXIDE you could try.
                    See link for price.
                    orsum.
                    • gripper
                      • Jun 2008
                      • 1156
                      Very messy to apply and limited effectiveness.
                      I used some of this to try and restore the glass on my Ellipsoids.
                      For what this cost me so far I could have bought an S2
                      • vonbeck
                        • 2455
                        hows this
                        • andy10v
                          • 5996
                          It will take hours to smooth it to the base level of the deepest pits/scratches.
                          My mate did some headlights and that took hours to wetsand through all the grits and then polish, I cant even imagine doing a windscreen.
                          A light polish should smooth the surface out, but wont touch deeper chips.
                          Sold ABY-stock
