Door hinge/ S -spring adjustment
  • hiloran
    • Mar 2010
    • 121
    I bought recently -93 Aby Coupe. Doors won´t quite stay open. Is there way to adjust the S -spring on the door hinge. I tried to bend it but did not make difference. Have the spring "died" over the years?
  • irishs2
    • Apr 2009
    • 2455
    If the hinge is weak then replacement is the only option, but sometimes the cams that catch the spring can spin incorrectly and not hold the door properly.
    The cams on the bottom of the hinge here catch the spring.
    Eric
    95 S2 Avant under rebuild.
    • hiloran
      • Mar 2010
      • 121
      Thanks. I looked at the cams but feels like the spring should press the cam a bit harder
        I have the same problem on my drivers door, passenger one is ok. I think about fixing it every time the door closes on my shin..
        • hiloran
          • Mar 2010
          • 121
          New lower hinge seem to be expensive ~140€ have to look for used ones if they would be better
          • A1QSHIP
            • Aug 2004
            • 975
            Find some used ones from a LHD drive car. The "passenger" side are not usually worn as much & still work to hold the door open.
            HTH, Chris
            "Nulla tenaci invia est via"
            • Tom_
              • Oct 2007
              • 1301
              • Country: Czech Republic
              Any ideas how solved a free moving doors at hinge? Any repair or modifying? Right and left doors are too free, it doesnt hold position, and if i stay with car from the hill, it kicks me to the ***
              Audi Coupe Quattro 2.3 20V
              • steve briance
                • Aug 2014
                • 1455
                The springs snap inside the bracket so you can't necessarily see the problem. There is no amount of adjusting that will help and this is why your don't won't hold open. Both my doors are like this, I've got spare hinges but they are a pain to fit and more pain again to adjust so I'm putting it off
                • mcandmar
                  • Apr 2004
                  • 5118
                  As above, if the spring isn't applying pressure all the time its scrap. I just changed my drivers door hinge and its so nice to have one that stays open in both positions, and doesn't drop when you open the door either.
                  The hinges are the same for the left and right side of the car so just grab some passenger door hings from a scrap yard. Its a pain in the butt having to repaint them to match, but worth it.
                  91CQ20v - Gone to a new home
                  93UR-S4 - The Magic Carpet
                  94S2Bus - The Emerald Express
                  • Tom_
                    • Oct 2007
                    • 1301
                    I have some hinges from another car, so i repaint them and will see. There two hinges on one side, right?So only change the bigger one with spring?
                    Thanks
                    • mcandmar
                      • Apr 2004
                      • 5118
                      Depends on how badly worn the top hinge is. If you open the door and try to lift it you will be able to see how much free play is in the hinges.
                      • Tom_
                        • Oct 2007
                        • 1301
                        Only that problem that hinges doesnt hold door in positions when i open/close doors. U need to hold door all the time when u are from or to hill
                        • kulster
                          • Sep 2007
                          • 290
                          Hi fitted brand new hinges to mine, you have remove the wing and door to change
                          • Tom_
                            • Oct 2007
                            • 1301
                            upper or lower? Because the bottom ones, that hold door in positions, isnt it?
                            Picture borrowed from Greg
                            number 5 (that lower one)
                            • mcandmar
                              • Apr 2004
                              • 5118
                              No you dont, open the door fully and place a jack under it to take the weight, i also recommend having an assistant hold it too for safety. To access the side bolt just remove the front wheel arch liner and plastic trim piece and you can reach in with a spanner to undo the nut.
                              Yes the lower one has the spring.
                              P.S. Don't ever try to open or close the spring by hand, always mount it in a vice and use a pair of vice grips. I can only imagine what would happen if you managed to close it with your finger inside
