Next issue... rear windscreen wiper
    Cheers Steve, I've proven the motor works, so I'll have to look at the other 2 things now.
    Where's the relay to?
    • Bowie69
      • Nov 2013
      • 2675
      Under the driver's side daash on a B3, but apparently may be under rear seat on a later Coupe...
        Ta
        • filio
          • Aug 2014
          • 8
          • Country: Bulgaria
          Just to make things clear. It's a long push that gives you water and three swipes. A single short push turns the wiper off.
            Removed and refitted the relay and it worked for a bit. Removed, cleaned the pins and refitted the relay and it seems OK now. Also checked the stalk but nothing untoward.
            • 220bhp
              • 2578
              • Home: United Kingdom
              #21
              All s2 rear wipers employ mindofitsown technology.
              • s2driveruk
                • 12696
                Lol yep the contact cleaner I squirted into the stalk has had mine working for years
                1992 3b S2 Coupe
                • johnboy 3169
                  • Nov 2009
                  • 300
                  Hi I have a couple of RS2 and one of them had the the option of mindofitsown rear wiper option fitted I tried all the options as mentioned above with no joy.
                  I then looked at the wiring loom that comes out of the N/S/R top part of the body/tailgate and hey presto all the wires were either worn through or broken, now fixed and its never missed a beat since
                  Maybe worth a look.
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
