RS2//S2 bumper differances
  • 220bhp
    • 2578
    • Home: United Kingdom
    I am fitting an RS2 bumper to my coupe. in a few weeks, is there anything that's different to the s2 when it comes to fitting it ,other than the indicators etc.
    What about the under headlight trims.
    I also need to replace the grills, which are missing.
    Its an original bumper, so is fixing it straight forward, any BTDT.
  • 220bhp
    • 2578
    • ColonialNomad
      • Feb 2015
      • 392
      • Home: United Kingdom Current: China
      I'm no expert but I believe there are some differences with RS2 foglights and there might be a slightly larger allowance for the RS2 intercooler. Have you searched on the forum for this information? I've found that sometimes my questions don't get a response because it's been covered elsewhere.
      • gavs20v
        • Sep 2004
        • 3057
        Hi ,
        The under tray is slightly different and I've found a bit of fiddling is required to line up with the inner arch trims .
        Fogs and indicators are plug and play . My pull need to make am adaptor for the washer jet hoses to the rs2 jets .
        Under headlight trims are different as the rs2 one have a 45deg angle to them however the s2 ones fit without issue
        Grill mesh is very rare , I replied on your other thread about buying an equivalent and cutting to suit
        Hth
        Gav
        S2 Cabriolet.........
        • 220bhp
          • 2578
          Many thanks
