Any of you guys ditched the heat shields from the under side of the car?
I've been refurbing my rear subframe and diff and noticed a fair bit of rust hidden away behind the back box shield. The shield itself is also rotten and by the looks of the rust and where it's starting I'm guessing it's a bimetallic reaction between the alu and steel that's causing the corrosion on the car and the shield.
I've sorted all the bodywork and now starting to rebuild so just wondering if it's worth patching up, sourcing new ones or just ditching the heat shield?
Carsten
thanks Carsten!
