Do Coupe lights fit an Avant?
  • cococarmichael
    • Jan 2011
    • 42
    Does anyone know if headlights from a coupe, cab or saloon fit on to an Avant?
    Having a bit of a time trying to find replacement headlights.
    Cheers,
    Colin
  • K Simmonds
    • Dec 2007
    • 7627
    S2 Coupe/Avant headlights are interchangeable, what model Avant do you have?
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • cococarmichael
      • Jan 2011
      • 42
      Ok thanks for that will make the search easier. I have a 94 aby s2 avant
      • martinjs
        • 3205
        What's wrong with yours?
        • cococarmichael
          • Jan 2011
          • 42
          I've had the car sorned for the past 18 months so decided to get it back on the road. Put in for MOT and it failed because the lights are too high and won't adjust along with a broken spring. The garage has said I need new lights which is proving quite difficult.
          • bluequattro
            • 2960
            You ll need ellipsoids then
            Final edition cabriolets have them
            I've only a near side one at moment for sale
            • cococarmichael
              • Jan 2011
              • 42
              I would be happy with any thing that fits and passes the MOT. If I get normal ones it will give me time to see if I can repair the original ones.
              Just out of intrest is it a right or left side you have?
              • cococarmichael
                • Jan 2011
                • 42
                Sorry just reread the post. Near side. Cheers
                  Do the electric adjusters work?
                    If you fit normals you might need to change the wiring a bit to get them to work. I've just done the reverse and changed from normal to elipsoid and had to move a wire in the light switch connector. I's documented on here as the Martinjs mod
                    • david1980
                      • May 2014
                      • 1025
                      You can rebuild ellipsoids using non very easily and cheaply
                        see below
                          did you read this?
                          • cococarmichael
                            • Jan 2011
                            • 42
                            I don't know if the electric adjusters work but I don't think I would need them for the mot
                              I think you said that your problem was that they were too high and would not adjust.
                              Ok, if the adjuster motors don't work, and / or the motors are right at the top, then the headlights will be too high.
                              Have you tried using the adjuster inside the car to focus them lower?
                              I bet the MOT station just tried to adjust with the screws on the lights themselves which are often seized..
