Fog lights
  • Dave
    • 58
    Fog lights
    Are these cars meant to have 2 fog lights on the rear.
    Only asking because when investigating some lights that had blown, I took off the left bulb cluster holder and found that 1-there was no bulb then 2- there was no hole for the bulb to go into the tail light.
    Any theories?
    Dave
    '93 ABY coupe
  • Martynf
    • 1885
    DAve, we only have one rear fog. BUT... it damn simple to get two :-) on the Avant, there is a piece of plastic in the hole, all you do is cut it out and fit a bulb and holder in there. The wiring is already there! so just pulg in and go :-) A £3.00 mod, wish they were all this easy!
    Martyn
    Martyn
    www.vagparts.com
    • Dave
      • 58
      Martyn [/B]
      If only!!
      I had a feeling it might be something like that, do you know why they only have one when the wiring and everything is there?
      Oh and is that your pet on the bike!!
      Dave
      '93 ABY coupe
      • Martynf
        • 1885
        Yup, German cars have always been like this, the theory is that if you have just the one rear fog light on the outside of the car (middle of the road side) then the car behind can clearly tell you have a fog light on and not that you're braking!
        Well, thats the theory anyhow! Thats my pet zebra on my bike
        Martyn
        www.vagparts.com
        • Sidspud
          • 1223
          • Home: Scotland Current: United Nations
          It is sooooo simple to get both fogs working and if you have a third brake light as well, then anyone behind would still be able to tell the difference.
          ex '93 Avant owner
          • Dave
            • 58
            How do you get a third brake light?
            Is it mucho complicato!
            Dave
            '93 ABY coupe
            • Sidspud
              • 1223
              I've got a third brake light on my spoiler.
              ex '93 Avant owner
              • Dr H
                • 1175
                The only problem with putting an extra bulb in is that there is no reflector in the other light so the bulb will be dimmer. I've looked at doing this but stopped when I found no silvery bits!
                Ex 1994 Avant - now driving a Lotus 340r
                • Martynf
                  • 1885
                  Leigh, have to disagree there mate.... I fitted the 'second' fog light a while back, no noticeable difference at all in level of light...
                  Martyn
                  Martyn
                  www.vagparts.com
                  • Sidspud
                    • 1223
                    When I ordered my bulb holder the parts guy commented on this.
                    My Avant had the reflector already there, so it looks like a proper install.
                    ex '93 Avant owner
                    • Cobstar
                      • 98
                      Hmm - now I wonder what's been wired up on the RS2 - I don't think I ever bothered to check. The S3 only has one rear fog light working and we've not got round to sorting that out.
                      Sidspud - your third brake light looks fantastic! I want one!
                      • Dr H
                        • 1175
                        @ Martin
                        me and my presumptions again! Does it have a reflector in there? I'm sure mine didn't.
                        So you just remove the blanking bit from the light and stick a bulb in?
                        Leigh
                        • Martynf
                          • 1885
                          I didn't really look to be honest!! just cut out the blanking plug and stick a bulb in there with a holder! the wiring was there, all I had to do was plug in and off it went! I didn't look to see if it had a reflector...!! but they do both look the same level of light output!
                          Martyn
                          Martyn
                          www.vagparts.com
