Avant Rear Doors
  • PaulJ
    • Jun 2008
    • 253
    Avant Rear Doors
    Hi Everyone
    Does anyone know whether the rear door frame me is the same on the saloon and the Avant. The part numbers are different. I need a replacement glass felt strip and have a chance of one from a saloon
    Any help would be appreciated
    Paul
    1995 RS2 Nogaro
    1971 Lotus Elan Sprint
    1974 Lotus Elan+2S 130/5
  • shaun5
    • 1610
    saloon and estate are slightly different
      Originally posted by PaulJ
      Hi Everyone
      Paul
      Can you show me the part you want? I have some avant window frames here.
      • PaulJ
        • Jun 2008
        • 253
        Hi, its the rubber and felt strip that the window runs in, part no 8A9 839 439 or 440, not sure which one is correct for OSR door, its the only one of mine which look the flock has worn off the rubber, not a clue how the seal comes out the frame, did not try too hard though as did not want to damage anything, Ill need to work out how to attach pics when using ipad
        1995 RS2 Nogaro
          I will have a look to see if I still have an OSR frame
