The sunroof on my s2 is dead. Never worked when I bought it. Does anyone know what the usual issues are? The motor doesnt click when the switch is operated. I've seen a relay next to the motor but can't find a fuse on first inspection? I want to take the sunroof panel out for painting. Is there an easy way to get it out or a link on here for instructions? Thanks in advance.
Sunroof
Sunroof
If the mechanism isn't completely seized, you can wind the sunroof back with the Allen key to allow you to see the front edge of the liner. If you reach over the liner you will feel the clips, push the prongs apart to help them open so the liner un clips from the roof panel and push the liner back into the cassette. You can then see the torx bolts which hold the roof panel to the mechanism, 3 on each side.Last edited by newsh; 4 May 2017, 20:18.
Oh and check the relay/controller module under the dash for dry joints.
With the headlining out you can remove either the sliding panel or the whole cassette [emoji106]
Just done mine a few weeks back can do it in 1 day if you get stuck in think there is a few complete cassettes on ebay at the minute, will be the easiest way to go. trying to repair them is a nightmare once the cords are seized or running tubes are corroded like mine were good luck
http://www.s2forum.com/forum/showthr...ssette&page=15 check this thread out it helped me loads
Thanks Rikki. I've had a good look at it today. The motor works ok but the cables are seized solid, i cant budge the sunroof even with the allen key. Looks like its the headlining out and a replacement off ebay (thanks for the tip)
Any tips for taking the headlining and surrounding trim out without butchering everything? It looks a pig to remove. Thanks. Tom.
Remove the pillar trims, the sun visors and the interior grab handles/ lights and the headlining will come down.
I even fitted an avant cassette in my coupe, only difference was the angle of the drain pipes
