Moving engine back
  • Lefrog
    • Feb 2017
    • 194
    Moving engine back
    Anyone got any experience moving there engine back on a b2 coupe Quattro to improve balance and handling ? Getting to the engine trial fit stage and while the grinders out didn't know whether to do it ?
    Any help appriciated.
    • Dec 2017
    • 6006
    Put a bag of sand in the boot
    • Rikki Kitto
      • Feb 2010
      • 6276
      I should imagine the limited amount of space and how far you can actually move it you probably won't feel any benefit for the work involved
        Steering rack / steering arms are the biggest obstacle
        • diesel des
          • 3896
          Yea you would need a different steering rack setup.
          Sent from my Moto G (5) using Tapatalk
          • mac2226
            • Jun 2008
            • 1289
            Look up terrybullwons racing s2 in projects it will give you the work that’s involved all best Michael
            • Lefrog
              • Feb 2017
              • 194
              Just found this online .
              • terrybullwon
                • Mar 2006
                • 8782
                Moving the Engine down and back is pretty simple. But like mentioned. You then run into two issues. Shaft to CV angle. Steering rack will then crash into the bell housing so you will need to cut it and weld it.
                I've done all of the above and its night and day different but the price for the CV joints is enough to put most off!
                Chef
