Wanting to fix an 01E gearbox into my UR Quattro
  • URQguy
    • Sep 2008
    • 245
    Any pictures in particular you want?
    The steering arms are a big headache with stock manfiolds/k04s. The steering bracket was modified, and custom arms were made with some odd bends to clear the turbos. Just delete the idea of using factory manifolds/turbos from your memory!!
    We also use the front bi pipes as well, but they really chew up real estate up front. The car is also in to change from the motronic APR software to full standalone VEMS. This will allow us to get rid of the maf problem and then just filter air coming off the turbo inlets. A lot of the OEM emissions controls are deleted too if you go standlone, which makes for a cleaner bay. There is so much stuff in this engine bay, it makes me want to vomit!
    I think a single setup using 2.8L NA manifolds with up pipes to a single turbo would be the easiest way to make good power. Guys have run single gt35r's on k04 files with great results.
    Also, the y pipe(the rs4 one atleast) hits the hood. This required us to drop the engine significantly to get it to clear. There were some compromises there.
    Feel free to ask more. I am off and on this forum, so be patient!
    1981 URQuattro with the TIAL GT35r.
    2007 Infinity g35
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      Hank,advice me when you had all the new 5 pot conversion parts done!
      • URQguy
        • Sep 2008
        • 245
        want me to include them in your latest package?
        2007 Infinity g35
        • ralleyquattro
          • Oct 2007
          • 536
          • Home: Poland Current: Canada
          Originally posted by URQguy
          Hank,
          Mike and I could use one of these trick gearbox mounts for the shift linkage tie rod.
          Let me know.
          www.quattro.ca
          B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
          B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
          • URQguy
            • Sep 2008
            • 245
            You bet. I am still in test mode. I'll send you guys a set when they get finalized
            2007 Infinity g35
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #21
              No no,I'll be happy with the wastegate for now.
              But I'd nice to see what's needed to use that newer rabbits engine into our engine bays....
              I'm sure you'll be able to send the whole thing in a pallet for a full conversion
              • URquattroGus
                • Aug 2007
                • 547
                Would be interested in one too....
                Angus
                (1984 ur quattro)
                • DJones
                  • Jun 2005
                  • 2020
                  Yep me too..
                  • jsws3
                    • Apr 2012
                    • 1174
                    Yep me 3
                    • DamoM
                      • Feb 2005
                      • 352
                      Hey. Thanks so much for the info. I Some pictures of the steering mods and arms plus some of the turbos and manifolds and one or two complete engine shots would be good! You did offer! ;-)
                      Did you retain std brakes? We went vacuum on the 20vt so are doing the same on this as it releases so much room.
                      We were going to go fmic. How are you going to upgrade your car's ones?
                      What rad did you use and does the car have Aircon?
                      Thanks so much mate!
                      *1986 ur quattro,2.5 stroker
                      *1995 Nogaro Blue RS2,Md357
                      *1991 RR 20v quattro
                      *2000 Nogaro Blue RS4,RS6 turbos,tubulars,custom 3" downpipes,Miltek,FMIC,big injectors,RS6 big brakes,RNS-E satnav/TV,592bhp/600lbs
                      • DamoM
                        • Feb 2005
                        • 352
                        Originally posted by DJones
                        Yep me too..
                        Hi Darren! It's been a while! The gtx3071r went on the 20vt today.
                        Bit of a squeeze!
                        • jsws3
                          • Apr 2012
                          • 1174
                          Did you map it today as well or just fit the turbo ?
                          As I'm interested to know how it performs .
                          • DamoM
                            • Feb 2005
                            • 352
                            It's getting mapped next week. Have high hopes for it. I have a Link ecu which is a doddle to tweak.
                            • AndyP
                              • 6049
                              [ATTACH]40718[/ATTACH]
                              Bit of a squeeze!
                              Is this the stroker or the RR?
                              • DamoM
                                • Feb 2005
                                • 352
                                This is the stroker. Have decided to keep the RR 100% std. Means I have a stack of spares that I'd accumulated to mod it now for sale! Inlet manifold, 2 md357 turbos, rs2 inlet manifold etc etc!
