Bit of Info from VAG
Ok just rang my local dealer - that sticker indicates the last service completed on the A/C by an official VAG source. They recommend a regas and leak check every two years and so long as the car is pushing out cool/cold air they normally expect a regas and some lube oil once a leak test is completed. If the car air is warm then either a larger leak or a stone in the radiator is quite likely at big £££££ to replace repair.
£115 for a regas and about 1.5 hours to do.
Hope that helps you all!
Cheers,
David
Cheers,
David
