In the US cars some folks are replacing the R12 in their older cars with a compatible replacement call "Autofrost". http://www.autofrost.com/..and others have replaced the R12 with R134...
The jury is still out as to how much of the R12 system has to be modified to adequately run with the R134...It is a given that the R12 Ester or lubricating oil for the compressor has to be replaced with one compatible with R134, and that the fill port needs an adaptor to work with the R134 equipement.
If the system has been open then it is a good idea to replace the reciever dryer ( the silver colored can). Some folks advise replacement of all the seals with R134 compatible ones, while others including some of the AC techs have stated that the R12 seals are so saturated with oil that this does NOT have to be done.
I think that the bottom line is how well you need the system to work and how much you want to spend. You may infact receive sufficient performance from a straight conversion (vacuum the remaining R12 and ester from the system, and insert the new ester and R134...)
Thats the extent of the conversion done on my CQ...
HTH
HTH
I was thinking about the belt slipping after reading about Martyn's stripdown,as the sound could well have been that,but the smoke very little actually,when i stopped and looked under the bonnet,i would say it looked and smelled like a very small oil leak,but not engine oil.I couldnt actually see where the smoke was coming from,it was very thin wisps from that general area,the car runs fine with the A/C off.
:confused:
