i was wondering if anyone could help me my car aby sliper wagon has a flat battery when i go out to it ...
the reason the fan keeps cutting in when ever i turn the ignition off..
the water is not hot and it should not be coming on..
with a bit of pulling off wires etc i have found it has nothing to do with the water temp sensors as its at the same speed as if the aircon is on and the only way ive got it to turn of is by disconnecting the air con plug on the radiator the red plug not the yellow one so my question to you all is what is this red wire for or what else could this be ( take out the relays etc and it still runs)only with said red wire of does it turn off anyone got any ideas tryed reading a few threads but none seem to cover this ..
any help much much needed,, the fan is not on when the bloody ignition is on only after,,, what is it ,,
