Could I get those pictures?
Blower motor fan
Originally posted by audimanMine does the same. makes a nice squeking noise every now and then. I just turn mineup to 4 or open the windows and listen to the noise of the turbo blowing hard
Your daddy works in porno
Now that mommy's not around
She used to love her heroin
But now she's underground
So you stay out late at night
And you do your coke for free
Drivin' your friends crazy
With your life's insanity
Makes the old dears at the bus stop turn sometimes.
Ck.Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
WD40 etc didn't work and the fan motor is a TOTAL COW to swap (air con avant) i mean a real cow to swap. Really its a dash out job to do, but if you get a second person to pull on the dash to the point of breaking it in two, then the motor CAN be changed without removing the dash. one bitch of a job.
Martyn & co.,
Did you ever get round to that "How To?"
My fan is making a hell of a racket - usual symptoms compared to other S2's here...noisy on speed 1 & 2 and gets better the faster you want the fan to turn.
It now appears that of the three central vents in the centre console, air is really only coming out of the RHS one.
The general consensus would appear to be that if the fan is making a racket, it needs lubing? Is that correct?
Is there not another way to lube the system?
F**k taking the dash out.
Just as I got the a/c working...
00 Audi B5 S4 MRC550
08 RRS TDV6 HSE
03 Kawasaki B2 ZX12R 1287cc
Originally posted by audimanonly does 15 mpg going to work and back, I use over a gallon a day!
Ok, not at the moment - when I get back into Kitty I will - but for now I can compete with you for "economy" because I am driving Mavis the Micra, easy 45-50mpg, and 50 miles is exactly what I do - it's just no fun though...
__MDC__Martin Cutting
