Heater woes, again... need wiring diagram !!
  • Heater woes, again... need wiring diagram !!
    Hi Guys,
    I have posted before about my heater blower problems. Brief reminder, it worked intermittently and then stopped completely. I replaced the motor and it worked for a while... Then changed the resistor pack, but nothing ! So I am suspecting the switch or a wiring fault ? Is there any other pairs in the system I need to check. I checked the fuse in the main panel and its OK.
    Does anyone have a wiring diagram so I can do some testing...
    Its a real pain this time of year......
    Many Thanks
    PAUL
    Does your car have air conditioning ? This page is for a manual air-con car - http://s2-audi.co.uk/workshop/schema...nual/page5.png
    Mike
    http://www.s2-audi.co.uk
      Mike, Thanks for this. My car has manual AC so this is the correct diagram... perfect. Now lets see what could be wrong...
        The full schematic is here of course - B76 - note the error as well that I once documented on S2central.com for this schematic (Error – Sheet 76/2 incorrectly shows relay in pos 11 as J26. This should be J101).
