Hard to find Coolant leak on s2 3b
  • 220bhp
    • 2578
    • Home: United Kingdom
    I have a small coolant leak somewhere under the distributor which I just can’t see . It drips under the car when pressurised but, I just can’t see from where .
    it may be one of the heater hoses which I have by passed recently due to a failed matrix but they both look ok .
    if anyone has experiences anything like this it would be good to hear from you before I start removing things to find out the cause
    If it the heater hoses where is the best place to source them and there part numbers
    thanks in anticipation.
  • Nuvo
    • Nov 2003
    • 3826
    Take a look at items 32 and 33. shown in the diagram below.
    • 220bhp
      • 2578
      Thanks Nuvo had a good look at that unit with a light and a mirror and, it is not leaking from there . Also the core plug near it is ok .
      its dripping from the gearbox but I cannot see where it’s tracking from , I can only assume it’s one of the two heater hoses rubbed through or something like that . I can see the connections to the metal pipe that runs under the water rail and that seems ok .
      If I am going to remove a load of stuff I might as well replace the two heater hoses . Anyone know the part numbers for those two hoses.
        Hi Lou
        I've had the item 33 elbow and the core plug both rust out on my 3B, also had to replace both heater hoses, I fitted the Samco water hose kit. I believe Roose do those hoses too, if you still have the original steel item 32 it will rust out, I would replace it with the ABY version or a billet one from Alex.
        IIRC the ABY and 3B elbows are different diameters? So the hoses are slightly different at the engine end.
        • 220bhp
          • 2578
          Found the culprit . New silicon hoses on the way but , I am not looking forward to fitting them .
          This gallery has 1 photos.
