metal particals in air con lines
  • denniselbows
    • 740
    hi guys right among over thing i am sorting out i am having my air con pump reconditioned and have found metal particals in my air con pipe work how can i flush all this out to stop damaging the pump? a friend has mentioned all the pipes have to be undone and a foam of some sort spayed in to clear all the lines. any ideas of cost please.
    never set your expectations to high that way you are never disapointed
  • rj scotty
    • May 2006
    • 2195
    If you got access to a compressor and wash gun, spray some IPA down them.
    Should do the trick
    cheers
    rich
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
    • Tommy200rs
      • 285
      the system should have the in line filter . See from etka and locate it and change it. Cleaning the system is very tricky because of oil in pipes. I see the only alternative to chnage the filter carefully. If cleaning with strange fluids you need to clean then the residues of cleaning material later and change in both cases the dryer unit.
      locate the filter and tell how it looked like ?
      • Jay
        • Jul 2004
        • 599
        cleaning
        If you take it to a air-con specialist they will do it for you. Just refit everything including a new receiver drier but leave the belt off so when you drive it to them there is no danger of compressor turning (unless you find a mobile specialist!!).
        DON'T use any chemicals in the system as these may damage the seals and may react with the gas to form acids that will attack the alloy piping Plus the air-con service machine does a sniff test when you first attach and if it detects foreign chemicals it will refuse to operate!
        The air-con bloke will flood fill the system with liquid R134a (air-con gas) and pump it around the system and through a filter (another remote reciever dier) and is air con station away from the compressor eg backwards and this will wash out any dirt.
        The ONLY otherway is replace every pipe,seal,condenser and evaporater (radiators) and you dont want to do that from a cost and a work point of view.
        Your probably looking at £180 to back flush the system but that does include the regas at the end, it is very labour intensive (aprox 3 hrs dependent on the car)
        If you don't believe me get advice from your local air-con specialists (look in the yellow pages)... I used to be a air-con engineer
        Jay
        • denniselbows
          • 740
          thanks for the advice i did think it would be a long job to clean out. sound like a job for the air con specialists
