The Afterrun Pump - Part numbers and Suppliers
This is a sticky topic.
  • CoupeWannabeS2
    • 403
    Hi there,
    Wondered if the collective could help me ?
    Have had a coolant leak for a week or two and finally had the chance to find what the problem is.
    The leak is coming from this part. I have removed it and it looks like a water pump / after run pump. Is this correct ? The part no is 392 020 054.
    Can the S2 function without it, like it can cope without the aux radiator, or is it best to replace it ? If I need a new one where would be best to go to get one ? Or has any one got one to sell ?
  • topsparky
    • Oct 2005
    • 2014
    thats the after run pump mate
    its function is to cool the turbo after a good thrash
    similar to a turbo timer
    it pumps water around the turbo when the car has stopped
    so as not to damage the turbo and therefore letting it cool down slowly
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
    • Dan_s2_coupe
      • Aug 2006
      • 482
      Are these very expensive as dont think mine runs the fan cuts in a minuite or so after i switch the car off if its hot but i felt the pump when the fan was running didnt feel like it was running
      I am thinking the sensor is ok as the fan is cutting in
      • terrybullwon
        • Mar 2006
        • 8782
        @Dan think i got mine from the stearlers from just under £120 iirc easy fit
        Chef
        • Briggsy
          • Jul 2005
          • 267
          @ Dan s2 coupe: you can check if the pump runs by getting a mate to turn the ignition on and you stand at the engine, you can hear the pump run for a few seconds!
          1995 B4 Audi 80 S2 avant 267bhp and 326lbft *sold*
          2001 P38 Range Rover DHSE 159bhp and 255lbft
          1985 Type85 Audi 90 quattro 135bhp 140lbft
          • CoupeWannabeS2
            • 403
            Thanks for the help, I have found what seems to be a direct replacement at GSF car parts, it's £65 and is on their website as a "water pump - additional". I'm heading there later to get one and to use the 10% forum discount.
            • dm80
              • Apr 2005
              • 812
              What's the consequences of running without this? I had the very same problem, and it's been bypassed in the interim. Should I be worried, and get this replaced soon as yeah?
              • Azman
                • 3205
                IIRC other VAG car afterrun pumps fit and they only cost about £70. Can't remeber which one though
                Dark Grey Avant
                RS2 FARB
                Alloy Subframe Bushes
                • CoupeWannabeS2
                  • 403
                  In respect of running without the pump, I guess in an extreme case it could harm the turbo.
                  Perhaps if you always leave the engine running for a while after a thrashing to allow the rest of the cooling system to reduce the heat. I dont know for sure if this would be enough, so please correct me if i'm wrong.
                    When the engine is shut off, and the engine coolant temperature at the exit of the cylinder head is above 110C, (230F) a secondary electric water pump turns on, which provides circulating coolant through the top coolant line down into the turbo and then into the engine block to ensure any bubbles from the boiling coolant get purged
                    It's there for a reason! get it replaced it cost £65 from GSF or theres a direct Bosch replacement from a washing machine IIRC on an old forum post.
                    • dm80
                      • Apr 2005
                      • 812
                      Could you tell me the GSF part number I need? Cheers.
                      • CoupeWannabeS2
                        • 403
                        The part number for GSF car parts is 17072.
                        • Jas11n
                          • 5067
                          Be careful of the one from GSF, the multiplug on the new doesn't match the old.
                          MikeS2 went through this last year.
                          Jas..
                          2001 Avus Silver B5 RS4.
                          1995 S2 Coupe - sold (sniff)
                            Jas..
                            I forgot about that Jas, cheers for the head up
                            Found the old thread http://www.s2forum.com/forum/showthread.php?t=15740
                            Pump is also from a T4 transporter alternatively the Bosch part number for pump is 0-392-020-054
                            • dm80
                              • Apr 2005
                              • 812
                              Brilliant. What a forum!
