Heater fault
  • jubjub
    • Nov 2003
    • 1239
    Heater fault
    Now the heater has started playing up of all things You turn it on and noting comes out,hot or cold.....However driving home tonight i noticed when i went round a roundabout the heater started working Does it have its own water system or something? Or is it just completely knackered.....
    • 12431
    have you got aircon fitted?
    I guess the fan is working?
    • jubjub
      • Nov 2003
      • 1239
      Yes it has got aircon but have nver had it working... It needed regassing when i first bought it, but it the transpired it had a leak When you fire it up tho you can here the thing working but get no cold air.A good few weeks ago tho even that stopped happening.
      • spink
        • 4382
        It could be the resistor pack,found inside the heater duct next to the motor. Quite a common fault on 80 and 90's,
        • jubjub
          • Nov 2003
          • 1239
          @ Spink - Where abouts is that?
            • 12431
            If you look down by the blower motor behind the glove box
            there is a cover at the top of the fan where the resistors are, this cover comes off and you can see it.
            I took the aircon off mine earlier this year and got a fan and heater duct for £10 from a scrappy.
            • spink
              • 4382
              Ive got one around here if you need it.I was going to bin it in a couple of weeks.
              • Stick Insect
                • Dec 2003
                • 2338
                Re: Heater fault
                Jameswkr had this problem, I think it was cured following a proper coolant bleeding session.
                Jubjub, there is a small bleed valve on the bulkhead at the back of the engine ( small black plastic knob on a rubber pipe. If I could suggest you try this.
                Bleed the system properly as expensive problems can occur. My colleague needed a new head gasket when her car wasn't bled properly by a dodgy garage.
                You will need to do it several times before it is right.
                Don't forget the correct anti freeze!
                HTH
                David
                • jubjub
                  • Nov 2003
                  • 1239
                  Re: Re: Heater fault
                  [i]Originally posted by Stick Insect
                  :eek2: :eek2: Thanks for that.... try and get that checked out ASAP
                  • Stick Insect
                    • Dec 2003
                    • 2338
                    Sarah's car needs a new head gasket now, a poor repair was done on her Citroen ( by a back street garage in Sheffield) and they didn't bleed the system properly!
                    She had a hose leak, a new hose was fitted and the heater didn't work afterwards!
                    Contagious thread again
                    David
