So I charged my AC on my CQ which has retrofitted B4 Climate control. And it does work...sort of. The control head says all is well and that the AC is on. The trigger wire from the head is being grounded when I turn the AC on. Unfortunately my AC relay doesn't appear to be working. Does anyone have or know the pinouts on it?
I know:
87: To AC clutch(is bridged with 30 upon trigger)
30: +
5/T: + trigger wire(+ w/ ignition)
31: ground (is controlled by HVAC head)
87a: ???
Does anyone know what 87a is? It goes to pin 24a(this is also bridged to 8a) on the early Hitachi ECU. I think it is just a signal(12v w/ ac clutch engauged, 0 w/ it not) wire for the Hitachi ECU but I am not positive on that. Does it need to be connected for the relay to work? I had it bypassed since the B4CC can do this function with one of it's own outputs. I tried reconnecting and it didn't do anything.
I'm think my relay coincidentally failed since working 6 months ago or I somehow burnt it out. Although I am not sure how since all looks good, unless the 87a does more than I thought.
I know:
30: +
87a: ???
